Is your battery draining too quickly? Do you simply want to know how much time you have left before you need to recharge? Then GSam Battery Monitor to the rescue!
• Hunt down those battery draining Apps with the App Sucker
• Always know your battery state and time left estimates with a optional status bar notification
• Overlay the stock battery icon with the icon pack add-on.
• Dig deep into how an App uses your battery - including wakelock details
• Sort your app suckers by things such as CPU & sensor usage, app wakelocks, wake time, and kernel wakelocks.
• Set a custom time reference to see stats over a certain period of time.
• See time remaining estimates based on current and historical usage
• See historical averages - how long does your battery usually last?
• Add a widget to your home screen showing the battery status and time remaining
• Include all sorts of great battery information in your DashClock widget using the included DashClock Extension
• Download or create your own icon themes
• Set customizable alarms for various charge states, temperature, and battery health
The professional edition also includes
• Optimized views for Tablets or other devices with large screens.
• More accurate time remaining estimates for devices such as tablets with long standby times.
Paid / patched version
️ GSam Battery Monitor Pro v3.46 Build 1903460 (11.46 MB)
