File size: 62.9 MB
µTorrent - a quick, easy, free and compact torrent klent. Client µTorrent, today, is one of the most popular solutions for network BitTorrent. The program combines optimum functionality with a small amount. Supports the work regardless of the trekkers, lets you download multiple files at once, has a customizable bandwidth, rapid restoration of interrupted downloads, and more.
µTorrent - a totally free software for file sharing on P2P technology in the file-sharing network BitTorrent. From other clients uTorrent features a small size distribution, although in the present day "terabytes and gigahertz," the size of uTorrent, called the sole and unique advantage will probably be wrong, but on the other hand it is confirmation of the quality and professionalism of the uTorrent programmers who can write a "compact" code.
One of the best uTorrent has become a convenient, well thought out, very nice interface and fast response to user actions. It supports all the necessary functions for operation in BitTorrent P2P-network.
There are some features
uTorrent supports parallel loading;
Rational use of bandwidth and allows you to customize it;
Built-in scheduler uTorrent manages tasks;
uTorrent has the ability to set the priority of traffic and adjust the speed;
It has features a quick stop and resume downloads;
uTorrent supports UPnP and NAT-PMP, as well as popular protocol extensions;
It has low memory consumption and small size of the program;
Supports reading RSS-feeds and download torrent-announcements;
Interacts with other customers without the need for the main tracker (DHT);
uTorrent supports the Protocol Encryption;
Interface uTorrent has supported the change order and the possibility of translation into other languages;
In uTorrent integrated remote control via HTTP-protocol, using web-interface (WebUI);
uTorrent works in all versions of OS Windows;
It is also possible to use uTorrent in Linux using Wine.
µTorrent is one of the most popular BitTorrent clients, with plenty of features such as bandwidth prioritization, RSS auto-downloading, scheduling and Mainline DHT (which is compatible with BitComet, another well-known BitTorrent client), Protocol Encryption joint specification (used also by Azureus 4.7.0.0 and above, BitComet 1.30 +) and peer exchange.
µTorrent was written with efficiency in mind. Unlike many torrent clients, it does not hog valuable system resources - typically using less than 6 MB of memory, allowing you to use the computer as if it weren't there at all. Additionally, the program itself is contained within a single executable less than 750 KB in size.
Features of µTorrent
- Multiple simultaneous downloads
- Configurable bandwidth scheduler
- Global and per-torrent speed limiting
- Quick-resumes interrupted transfers
- RSS Downloader
- Trackerless support (Mainline DHT)
PRO FEATURES
• Stream Instantly (beta)
• Automatic protection from viruses and malware
• Play more formats
• µTorrent Pro includes an HD media player or convert to play on any mobile device.
• µTorrent Pro is always adding new features. Enjoy them at no extra cost.
• Convert downloads to play on any device
• Premium customer support
Langpacks: Albanian, Arabic, Azerbaijani, Basque, Belarusian, Bosnian, Bulgarian, Catalan, Chinese (Simplified), Chinese (Traditional), Croatian, Czech, Danish, Dutch, Estonian, Finnish, French, Frisian, Galician, German, Greek, Hebrew, Hungarian, Icelandic, Italian, Japanese, Korean, Latvian, Lithuanian, Macedonian, Malay, Norwegian, Persian, Polish, Portuguese (Brazil), Portuguese (Portugal), Romanian, Russian, Serbian (Cyrillic), Serbian (Latin), Slovak, Slovenian, Spanish, Swedish, Taiwan, Thai, Turkish, Ukrainian, Valencian, Vietnamese.
