Erin is a state-of-the-art plugin suite dedicated solely to mastering. It includes 5 studio processors sampled from world-class mastering equipment, which was manufactured by one of the most prestigious pro audio designers in the world. He has been known since the early 70s for his innovative approach in the field of tube-based systems for the high-end, hi-fi market.
A Truly Luxurious Mastering Suite
Erin includes 5 different plugins: a 5-band stereo tube equalizer, a stereo tube compressor/limiter, a midrange tube equalizer, a mono "hyper" compressor/brickwall limiter, and a "hyper" stereo tube compressor/limiter.
Erin Stereo Tube EQ
The Erin EQ ST is a faithful emulation of an esoteric 5-band stereo parametric equalizer that is mainly used in mastering facilities. Its prohibitive cost makes it difficult to acquire one of your own, yet it's one of the most revered equalizers on the market for shaping tracks of any genre.
We sourced an immaculate specimen of this exclusive unit, carefully sampling it to offer you the same creative firepower that only the highest-end mastering rooms had previously been able to access.
Each of the 2 channels of the EQ features 5 bands, hi-shelf and low-shelf filters with gain, and fixed Q controls. The plugin is also equipped with 3 boost/cut filters with adjustable center frequency. Either band or the preamp can be bypassed at any time using the dedicated button controls.
Erin EQ ST features our new Ultragain matching technology, ensuring extremely accurate gain mapping on all bands. It provides even the most demanding mastering engineers with perfect resolution, consistency, and response, all while retaining the original sonic character of this sought-after. hardware.
Erin Midrange EQ
As the name implies, Erin EQ Mid is designed for use on the sound's midrange, focusing on frequencies between 200Hz and 5kHz. It'sa faithful emulation of an extremely intuitive tube unit made in the UK, and is reminiscent of Pultec-style tube designs.
It features a limited number of selectable frequencies, which are placed closer to each other compared to other EQ designs. This gives you even more precise control over this critical part of the spectrum.
Finally, a colorful preamp stage and dedicated mid/side, left/right controls make it a versatile processor that easily adapts to specialized uses. It works wonders on those sources that live in the midrange of a mix, such as violins, guitars, and vocals.
Erin Compressor
Erin Comp is a stereo tube compressor/limiter derived from an esoteric mono unit manufactured in the UK, which was designed to limit or compress the signal with the minimum of interference below the threshold. Our plugin version is intuitively simple to operate, and features standard attack and release times.
A strongly optimized behavior around the "knee" of the attack/decay envelope and a euphonically transparent dynamic action make this compressor a top choice for mixers, mastering wizards, and demanding artists with experience in the studio. It's not by chance that legendary Pink Floyd frontman and guitarist David Gilmour installed two of these processors in his Astoria recording studio.
Erin: Update (Release C001)
What's New with Erin?
This new Erin update contains significant new features that improve performance and sound quality.
These include
2 new standalone plugins: Erin Mono Hyper Comp and Erin Hyper Stereo Comp.
New Hyper engine.
New Hyper compressor/brickwall limiter emulations.
Improved audio quality thanks to the oversampling available in the Erin mono compressor.
Less CPU consumption.
Oversampling (only in Erin Mono Hyper Comp)
Various optimizations and graphical improvements.
Resizable interface for the entire plugin suite.
Erin Mono Hyper Comp (ERINHYCOMP)
The mono Hyper compressor and brickwall limiter are based on our new Hyper compression technology.
The heart of this plugin is the presence of two new brickwall limiters: the first is more "traditional" and the second more "pioneering" in their respective conceptions. Both were created from samples of analog dynamic processors, which were then converted to brickwall limiters; this is an innovative feature for a product that is characterized by a strong prevalence of limiters using program-dependent digital releases.
Erin Stereo Hyper Tube Compressor/ Limiter (ERINHYCOMPST)
We've taken the Erin Stereo Comp plugin to a whole new level thanks to our Hyper compression technology. The resulting tube compressor/limiter includes 4 new powerful Hyper compressor emulations, offering faster and more accurate compression with reduced CPU consumption.
official site does not provide any info about changes in this version.
️ Acustica Audio Erin 2023 (515.2 MB)
