Amolto Call Recorder Premium for Skype 3.28.1 | Size: 33.96 MB
Amolto Call Recorder is the best tool for recording your Skype conversations. It works together with Skype or other VOIP applications and records in high-quality video and audio format. Amolto has easy to use user interface, starts recording automatically when Skype call starts.
- Automated: recording starts automatically with your call.
- Full Quality: records are saved in a high-quality audio format to match the clarity of the call itself.
- Unlimited: no limit on recording time. Never lose a minute of your conversation!
- Track & Annotate: quickly search or sort your call history. Add notes or Mp3-tags to any record to emphasize key points in your conversation.
If you often rely on Skype to keep in touch with your overseas friends, then recording your calls could come in handy, as you could listen to the recordings whenever you miss your buddies. Amolto Call Recorder for Skype can help you achieve this.
The app installs without any issues and you will simply need to authorize it within Skype in order to enjoy its functions. It will automatically start recording any detected chats, so no additional input on your side is required.
The interface of the app is user-friendly and intuitive, and it displays the status of your microphone and headphones so you can be sure you can initiate high-quality Skype calls.
Amolto Call Recorder for Skype includes a dedicated section where you can explore all recorded calls; you can play them using the default audio player on your PC, or you can analyze additional data, such as duration, audio size or start time.
All calls will be saved to MP3, a format that is supported by a wide range of devices, including mobile phones or portable players, so you can listen to them even while on the go. You can customize the details of each entry by assigning it dedicated tags, namely title, artist, album or year.
Furthermore, you can specify the type of recording you prefer, as the app can capture only your voice, only your friendпїЅs or both, depending exclusively on your choice.
All in all, Amolto Call Recorder for Skype can come in handy if you want to save your Skype chats and listen to them over and over, even if your friend is offline. However, if you also want to be able to capture video calls, you need to upgrade to Amolto Call Recorder Premium or another third-party app.
