Free Download Batch DOC to Help Generator 2023.15.928.3763 | 1.4 Mb
Batch DOC TO CHM Generator is a Help Authoring Tool that can convert Word DOC to CHM HTML Help and Manual automatically. Batch DOC TO CHM Generator supports powerful search for a lot of files. An easy-use Word to CHM, Doc to Help & Manual Converter.
Batch DOC TO CHM Generator supports project and command line. Batch DOC TO CHM Converter has a friendly GUI so it is used very easily. Batch DOC TO CHM Generator Drag and Explorer Context supported.
Batch DOC TO CHM Generator supports an efficient Multi-Thread conversion engine. So you could control the conversion action very easily. You can stop or pause and continue it in any time.
You can save your conversion work in a project file (.batch-doc2chm) for re-use. You can run the batch-doc2chm project in Microsoft Windows Explorer or command line directly.
The main features of Batch DOC to Help Generator:
Convert Word DOC to CHM HTML Help and Manual automatically.
Batch convert DOC to CHM with GUI that supports powerful search function.
Supports convert a doc/docx file.
Supports convert doc/docx files in a folder.
Drag and context menu with Microsoft Explorer supported.
Supports batch project and command line.
An efficient high-speed Multi-Thread conversion engine.
System requirements:
Intel x86/x64, Microsoft Windows XP/Vista/Win7/Win8/WinServer 2000-2012, Microsoft Word 2000-2013
Home Page-http://www.batchwork.com/en/doc2chm/
