Free Download Craft Edge Sure Cuts A Lot 6.038 Multilingual Free Download | 86.8 Mb
"Sure Cuts A Lot" is an extremely easy program to allow you to cut virtually any shape with your electronic cutting machines. With the combination of using your fonts, importing custom artwork and drawing your own shapes, the possibilities are endless!
What's New in Version 6:
New effects added, including Cast Shadow, Monogram, Rays, Rhinestone Scatter.
More options to customize Rhinestone designs.
Create Data Source Copies, to easily replace text for different variations of the same design.
Set cut lines to be scored.
More options to choose, select, and replace colors
More path options to Divide overlapping shapes.
Convert square corners to rounded corners.
Text is now imported from SVG and PDF files.
Larger workspace area.
Generate bar codes (PRO version only).
Options to control the cut order (PRO version only).
Apple Silicon (M1,M2) Native Mac versions.
and more!
Sure Cuts A Lot 6 supports a variety of electronic cutting machines:
Black Cat Cougar/Lynx
BossKut Gazelle
Brother ScanNCut (export as FCM compatible files only) *
Craftwell eCraft
CraftRobo
Cricut Air/Explore/Joy/Maker (export as SVG to upload into Design Space only) *
GCC
Graphtec
Foison
i-Craft
Janome Artistic Edge
KNK
Liyu
Mimaki
MyDigiDi
Pazzles Inspiration/Pro/Vue
PrismCut
Ramtin
Roland
Saga
Seiki
Silhouette SD/CAMEO/Portrait/Curio
Silver Bullet
Siser Juliet/Romeo
SkyCut
StarCraft SOLO
Teneth
USCutter Copam/LaserPoint/MH/PCUT/SC/TC/TITAN
Vicsign
Vinyl Express
Wishblade
and more!
Features:
Works with your installed TrueType and OpenType fonts
Works with thousands of free TrueType Fonts including Dingbat/Wingding Fonts
Import various file formats, including SVG, PDF, EPS, AI, WPC, PES,PEC,HUS,JEF,SEW,VIP (PRO Version can also import PLT, DXF)
Drawing tools to draw and edit shapes
Weld overlapping letters and shapes together
Select styles, including Shadow and Blackout, to change the look of your letters and shapes with just a few clicks.
Auto tracing feature to automatically convert images (including jpg, bmp, gif, png) for cutting
Create rhinestone templates & Lattice shapes
Create and cut projects up to 72 inches in length. (PRO Version does not have this limit)
Print & Cut*
Includes over 200 built in shapes, with many more available through the Cutters Market.
WYSIWYG Interface - What you see is what you cut
Interface can be set to English,Chinese,Dutch,French,German,Italian,Portuguese,Spanish
Save your design layouts, so you can save and share your designs
Pentium processor-based PC or compatible computer
Windows XP SP3/Vista/7/8/10/11
512 MB of RAM or more
At least 50 MB of available hard disk space
USB Port 1.1 or 2.x
Home Page-http://www.craftedge.com/
