Farid-Khan
2023.06.08.
32,966
304
35
File size: 87 MB​
Sure Cuts A Lot Pro is an extremely easy program to allow you to cut virtually any shape with your electronic cutting machines, vinyl cutters and plotters. With the combination of using your fonts, importing custom artwork and drawing your own shapes, the possibilities are endless!
? Features
Works with your installed TrueType and OpenType fonts
Works with thousands of free TrueType Fonts including Dingbat/Wingding Fonts
Import various file formats, including SVG, PDF, EPS, AI, WPC, DXF, PLT, PES,PEC,HUS,JEF,SEW,VIP
Drawing tools to draw and edit shapes
Weld overlapping letters and shapes together
Select styles, including Shadow and Blackout, to change the look of your letters and shapes with just a fewclicks.
Auto tracing feature to automatically convert images for cutting
Create rhinestone templates
Print & Cut for supported models
Includes over 200 built in shapes, with many more available through the eshape store.
WYSIWYG Interface - What you see is what you cut
Availble for Windows and Macintosh OSX
Interface can be set to English,Chinese,Dutch,French,German,Italian,Portuguese,Spanish
Free technical support
And much more!
? Pro Features
Extended cutting length to cut longer than 72 inches
Weeding options to easily add weeding boxes and lines
Tiling
Duplicate cutting
Cut by color
Color layer alignment
Print & Cut (Contour Cutting)*
3D shadow
Import DXF, PLT
Assign cut presets to layers
Options to control the cut order
License: full_version
Author: Craft Edge
⭐Craft Edge Sure Cuts A Lot Pro 6.046 Multilingual ✅ (86.68 MB)
DDownload Link(s)
