Derivative TouchDesigner Pro 2022.35320 (x64) | Size: 2.13 GB
TouchDesigner is a visual development platform that equips you with the tools you need to create stunning realtime projects and rich user experiences. Whether you're creating interactive media systems, architectural projections, live music visuals, or simply rapid-prototyping your latest creative impulse, TouchDesigner is the platform that can do it all.
INTEROPERABILITY
TouchDesigner works well with the world around it. Whether it is other software, protocols, hardware devices, or the web, extensive options for interoperability let you integrate TouchDesigner into any environment.
APPLICATION BUILDING
TouchDesigner allows both application engine and interface to be built in one integrated environment. Create anything from simple functional prototypes right up to complete polished applications.
HIGH PERFORMANCE MEDIA SYSTEMS
TouchDesigner is the highest performance video playback software available today. It will let you play more movies, at higher resolution or at higher frame rates, to maximize your hardware's potential.
REALTIME 3D AND COMPOSITING
Realtime 3D rendering combined with high resolution realtime compositing create a pixel playground that lets you discover entirely new ways of creating content.
PROJECTION MAPPING
Projection mapping involves custom solutions to every job, no two projection setups are the same. TouchDesigner's suite of features and customization options ensure any projection project is possible.
LIGHTING AND LIVE SHOWS
TouchDesigner technology can communicate with lighting equipment, audio systems, input and output devices, and show control systems used in all types of live show performances.
VR SUPPORT
All of TouchDesigner's other features work seamlessly with the built-in VR tools letting anyone get started quickly and easily with virtual reality.
EXTENSIBILITY AND CUSTOMIZATION
TouchDesigner offers the tools required to build completely customizable systems and extend functionality to meet the needs of your project.
