Free Download Devart dbForge Studio 2024 for Oracle 4.6.15 | 131.1 Mb
dbForge Studio for Oracle is a powerful integrated development environment (IDE), which helps Oracle SQL developers to increase PL/SQL coding speed, provides versatile data editing tools for managing in-database and external data.
This Oracle IDE allows synchronizing data between different Oracle servers and automating schema change management process during development. dbForge Oracle GUI features powerful functionality wrapped into a smooth management Oracle GUI consistent with Microsoft Visual Studio.
PL/SQL Development
Write and format code on the fly, debug procedures, functions, and triggers, optimize query performance and eliminate bottlenecks with:
IntelliSense-like PL/SQL code completion
PL/SQL formatter
Query Profiler
Code snippets
PL/SQL debugger
Data Modeling and Design
Design Oracle databases visually, build queries in a few clicks, create and edit database objects with:
Visual query builder
Visual database designer
Database diagrams
Visual editors for schema objects
Table designer
Database projects
Change Management and Data Manipulation
Migrate schemas and data between databases, manage data and schema diffs with:
Data import and data export
Schema export and import (dump)
Data comparison and synchronization
Schema comparison and synchronization
Analysis and Data Reporting
Design data reports, charts, pivot tables with parameters, customizable formatting, and calculated summaries. dbForge Studio for Oracle includes the following tools for efficient data reporting and analysis:
Data report designer
Pivot tables
Automated data report delivery
Object search
Compatibility:
Support for Oracle versions 8i, 9i, 10g, 11g, 12c, 18c, 19c, 21c
Oracle Cloud
Oracle Real Application Clusters
Oracle on Amazon RDS
Instant Client support
Direct server access
Using different Oracle Homes in a single application
Microsoft Windows 7/8/8.1/10/11
Windows Server 2008/2012/2016/2019
.NET Framework 4.7.2 or higher installed.
