Free Download Devart dbForge Unit Test for SQL Server 1.9.3 | 46.2 Mb
An intuitive and convenient GUI for implementing automated unit testing in SQL Server Management Studio. The dbForge SQL database unit testing tool is based on the open-source tSQLt framework, so SQL developers can now benefit from writing unit tests in regular T-SQL. The functionality of Unit Test allows you to develop stable and reliable code that can be properly regression-tested at the unit level.
Launch object testing in isolation without adding extra data for IDs
Tests won't affect the actual database and won't need clean-up code
Run multiple SQL Server unit tests at once in a few clicks
Automate and simplify your SQL unit test process
Invoke unit tests via the command line interface
Get started with built-in unit testing examples
Write unit tests in regular T-SQL code
