- · Megnézett téma PreSonus Studio One 6 Professional 6.6.1 Multilingual
- 15,549
File Size: 40.8 MB
The banner application runs as a great graphic-designed program for creating web-based or printable banner ads. It is a full featured with good design tools and fast way to build high quality banner images, provides a WYSIWYG interface for manipulation of vector graphics, allowing you to express yourself freely. The program offers high quality 2000+ ready-made professional banner templates, 500+ pre-designed clip arts & 5000+ vector symbols and amazed rendering filters. All of them help you to create stunning business banner ads for printing with high resolution. By it, you can visually design any web-based banners, buttons, headers etc. graphics and supports to save as SVG/EPS/PDF/EMF/WMF/PNG etc. file format.
Editable Vector Banner Templates
Offers 2000+ ready-made professional templates, You will find a wide range of professional looking designed banners by different industry categories and industry-standard sizes. Once the template is imported, it can be modified or adjusted as needed..
High quality 500+ Banner Templates
The application comes with 500+ pre-designed high quality templates. Just select a banner layout you like from the collection templates before design and then custom with your own drawing elements: photos, shapes, texts. That's really simple!
Eye-catched Banner Elements
Provide 500+ pre-designed clip arts & 5000+ vector symbols. You can add relevant design elements to your design as needed. This will greatly help you to start the process of banner creation. This means that for you there is no easier way to create amazing banners.
Button Templates and More...
Includes 200+ web button templates and 5000+ high-quality shapes, signs, symbols etc. graphics and many pre-built gradient style for rendering shapes and texts. You can use mouse drag or click to add the shapes to your design freely.
Professional Vector Drawing Tools
Offers creation of basic shapes (such as ellipses, rectangles, stars, polygons, and spirals) as well as the ability to transform and manipulate these basic shapes by rotation, stretching, and skewing. It also allows users to manipulate objects precisely by adjusting node points and curves.
Design Banners easily
The program interface is extremely user-friendly and allows you to create, move, scale, rotate and mirror shapes or texts only with drag or click. Make a professional-looking banner becomes really easy. Flip, mirror, group, ungroup, align and adjust z-order are featured for all layout drawing elements.
