EximiousSoft Business Card Designer Pro v5.15
File size: 33.64 MB
The business card software is equipped with featured design tools to create nice business cards quickly and easily. You can print the cards on your printer or export your design as pdf or jpg files and bring to a professional printshop for printing.
• Use supplied high quality 400+ templates, 5000+ shapes and 400+ clip-arts to start layout your cards.
• 400+ supported business card paper for ink jet and laser printers.
• A dozen or filters effects which can be used while working on all objects (texts, shapes, images, paths, backgrounds).
• Create one or two-sided cards, horizontal or vertical cards.
EximiousSoft Business Card Designer (Pro) Key Features
High quality 200+ Business Card templates, 2000+ Symbols and more...
• The program provides numerous pre-designed business card templates by expert designers, backgrounds & graphic symbols and lot more. With which to start design easily and quickly.
• Personalize them with your preferred images, logo, graphics & other elements in your business card design..
Powerful vector-based drawing tools
• Create any shape graphics as you desired with these tools. Move, delete or add even convert anchors for a shape with simple clicks or drag.That's really simple.
• Shapes or texts can be filled or stroken with solid color, gradient style or images high smoothly.anyone, Even have no design experience, can make stunning business cards with business card Software.
• Gives you the option to add drop shadows, reflection, glow, 3D bevel with customized settings to shapes or texts on your design.
• Any shape objects even texts can be stroken with more pre-designed dash style.
Design Business Cards visually and Easily
• Works like a great image editor program that supports strongly layer-editing. With the Layers feature you can control the position of various objects in your logo, you can place a more important object over the other and create different effects.
• To create, move, sacle, rotate, flip shapes or texts only with drag & click. Making professional-looking cards becomes really easy with application.
• The program is easy enough for everyone and doesn't require any designing skills thanks to a WYSIWYG interface - that is, what you see on the screen is exactly what your card will look like.
• Undo & Redo anywhere anytime.
Print Business cards freely
• Enable to print spectacular business cards on your own printer, on card stocks from Avery, Sigel, Herma, Formtec, DECAdry etc with high resolution.
• You can print 1 card or 5 card or 100 card, as you like. Most people print at least one full sheet of cards (8 or 10 cards on one sheet) for convenience.
• Supports to export cards to image files with high quality for print shop and print cards from your own printer directly.
Input & output in more popular image formats
• Supports to export your business cards to JPG, GIF, PNG, BMP, PCX, TGA, TIFF files.
• Allows to load image files from GIF, BMP, PCX, JPG, TIFF, PNG, TGA, PSD, ICO, CUR, ANI ect. files.
What's new
Supported System: Windows 11/10/8/7/XP/Vista
Homepage
A tartalom megtekintéséhez szükséges: Bejelentkezés vagy Regisztráció to view quote content!
