Full Battery Charge Alarm v1.0.268 | 5.68 MB |
Full Battery Charge Alarm lets you know when your battery is fully charged, so you can unplug your phone/tablet.
Stop unnecessary charging, take care of your device, save power and electricity.
How to use
Open the app, enable the alarm, change the settings if needed (ringtone, vibration, etc.), that's it!
- Helps you unplug your phone/tablet on-time.
- New optional bonus feature (beta): Low battery alarm/charge reminder (you can enable this & configure the percentage in settings).
- Set custom alarm ringtone (in the app settings), or disable sounds for the alarm.
- Use or disable vibration for the alarms.
- Material design looks.
- Simple and easy to use.
- Fast and lightweight.
- No bloat/unnecessary features.
- Clean and simple user interface.
- Free!
Full Battery Charge Alarm v1.0.268 (5.68 MB)
