GiliSoft Audio Toolbox Suite 10.8.0 Multilingual | Size: 60.15 MB
9 powerful and useful audio program in one pack, which including Audio Recorder , Audio Cutter, Audio Joiner, Audio Converter, Video to Mp3,ID3 Tag Editor,Transfer to iTunes,CD Ripper,CD Burner. #1 Audio Toolkit Suite is able to do almost every audio ripping, converting, burning, and editing imaginable. With it, you can easily convert and edit any audio files, rip, create and copy CD, convert audio files, burn music to CD, rip CD/DVD to different audio files, N/A
In conclusion, you can convert, copy, create, rip, burn and deal with your CD/audios/by #1 Audio Toolkit Suite with much enjoyment. Just free download and experience it now!
Audio Recorder
A nice tool that can enrich your music entertainment. It allows you to record streaming audio from music sites, video platforms, radio stations or capture sound from audio chats effortlessly. The software provides lots of output audio formats including MP3, AAC, FLAC, WMA, N/A for playing on any music players and portable devices smoothly..
Audio Cutter
A perfect tool for all your audio Mp3 Wav Wma cutting needs as create ringtones, make mash-ups, music clips and more. Cut your favorite part from a video or audio, save the result as a .MP3 file or ringtone for your mobile phone. Our app can be used to make an audio track fade in and out smoothly..
Audio Joiner
Audio Joiner has a very simple interface. Add your file, pick a start and finish time and press Cut, or find the file you want to merge with and press Join. The timescale slider is easier than usual to use, and you'll have the option to preview your work before making any final changes.
Audio Converter
The built-in audio converter offers lots of functions including cut, merge, mix and add effects to audio. Using it, you could re-create the audio and make ringtone without hassle. Except convert audio files , you can adust audio speed, change voice.
Video to MP3
Video to MP3 extract audio from video files to MP3 and WAV Lossless Audio. You can save audio in high, standard and economy quality. Video to MP3 Converter automatically fills the title tag and the artwork, taking a snapshot from the middle of video, which can be seen in iTunes, Winamp or just a Windows Explorer folder.
ID3 Tag Editor
ID3 Tag Editor is designed to be easy and intuitive to use. Just load the file you want to edit, enter the new information, and then add or edit tag metadata, including genre, title, artist, album, year, track number and more
Add your own comments to a music file, Edit wav, mp3 and ogg music file metadata.
Transfer to iTunes
Transfer Music on your PC Into iTunes, if you add video file, it will convert and transfer Into iTunes. If you want to listen to recorded music on Apple devices, the "Transfer Music to iTunes" function is the right option. It converts audio in any formats to iTunes compatible format and add them to iTunes library in one-stop way.
CD Ripper
A powerful software for ripping audio CD tracks to WMA, MP3, OGG, VQF, FLAC, APE and WAV formats. The interface is user-friendly and includes ID3 tag support. It supports multiple CD/DVD drivers and includes audio playback controls.
CD Burner
It's a nice add-on for you to burn your audio to blank CD for listening within CD player in your house or in the car. You may also share your songs with others via CD disc.
What's new
