File size: 85.4 MB
Glary Utilities is the number-one pro and all-in-one utility for cleaning and maintaining your PC. It includes more than 20 tools to maximize your computer's performance.
One-click Maintenance
One-click maintenance Integrates frequently used functions together. One-click to clean up junk files, fix system errors, clear privacy records, and optimize computer performance.
Free Up Drive Space
Disk Cleanup searches for old temporary files, obsolete installation files, log files, internet history and cache, error reports, save offline content and error logs etc. that you can safely delete on your computer.
Prevent errors or crashes
Based on years of experience, Glary Utilities can more safely clean up the errors in your registry to prevent some inexplicable program errors or system crashes. Also it can detect and fix disk corruption.
Make your computer run faster
Is your computer getting slower? Glary Utilities can help you identify and disable unnecessary startup programs that take up resources, or uninstall infrequently used software to free up more hard disk space.
Protect Your Privacy
Your browser will record the URL you have visited, and some software will also save the name of the file you opened last time. Glary Utilities can help you find and delete them. Glary Utilities can also help you completely delete files so that they cannot be recovered.
Keep Your Software Update To Date
The newer version of the software usually has better functions, higher performance, fixes bugs and vulnerabilities, and has better security, Glary Utilities can help you discover and update new versions in time.
Recover Lost or Deleted Files
Did you accidentally delete an important file? Did you also empty the Recycle Bin? Don't worry. Glary Utilities can help you find and restore them quickly.
Analyze Disk Space Usage
Are you running out of hard drive space? And you want to know which files or folders take up the most space? Disk Space Analyzer can quickly scan your hard disk and show you them sorted by size.
Find and Remove Duplicate Files
You may have downloaded the same file twice or backed up the same file twice. Duplicate Files Are Big Disk Space Hogs. Dupliate Finder can help you find and delete them.
