Malwarebytes Premium 4.6.2.282 (x86/x64) Multilingual
File size: 327 MB
[/center]
Malwarebytes is a high performance anti-malware application that thoroughly removes even the most advanced malware and spyware. Malwarebytes version 4.xx brings comprehensive protection against today's threat landscape so that you can finally replace your traditional antivirus.
Clean up your PC in minutes
We are famous for our free scan feature. In addition to detecting threats such as malware and viruses, it also identifies potentially unwanted programs that can slow down your system.
It protects you from online scammers
Web Protection blocks online scams, infected sites and malicious links, it also blocks phishing attempts that use fake sites to extract private information such as banking data.
Prevents ransomware attempts on your files
Using proprietary technology, Ransomware Protection creates a powerful defense against malware that locks down your PC and takes files and photos hostage.
Make your security simple
Our completely redesigned user interface makes it easy to customize your protection. You will be able to schedule scans, adjust protection layers and choose from three scan modes.
Introducing ... Malwarebytes Katana Engine
Our new detection engine finds more threats in less time and with less impact on performance. It also provides more information on detected threats, such as type and behavior, allowing you to make better security decisions. For example, rather than displaying a generic name of the threat, such as "Malware123," you will see a name such as "Spyware.PasswordStealer," with a link to information about that specific threat.
Malwarebytes Premium Benefits
Protects you from advanced (zero-day) threats, including ransomware, so you can surf the Web without worry
Removes all traces of malware for complete safety
Removes potentially unwanted programs (PUPs) that make your computer run poorly
Scans fast so you do not have to sit around and wait for your security to finish working
Easy to use, just set it and forget it
Can replace antivirus or run alongside other antivirus programs
Malwarebytes Anti-Malware screenshotMalwarebytes advanced technology protects businesses from the constantly-evolving threat that malware poses to corporate systems. From data loss to network corruption, undetected malware can decrease revenue and wreak havoc on your network. Malwarebytes provides maximum protection while using minimal resources, to keep your system focused on your business.
homepage
A tartalom megtekintéséhez szükséges: Bejelentkezés vagy Regisztráció to view quote content!
