Free Download Mercuriall Audio Ampbox v1.3.3 (x64) | 78.8 Mb
Mercuriall Ampbox is a next-gen VST/AU/AAX + standalone amp modeling plugin for PC/Mac. It's an ever-evolving platform for all* our products, current and future. You will get Ampbox for free when purchasing one of the supported plugins*. The platform has everything you need to create perfect tones with just one plugin. It's simple, elegant and versatile. Powered by Mercuriall Neural Hybrid Engine v2.0 technology.
* Ampbox supports the following products at this point: Dual Rectofire, Euphoria, ReAxis, U530. More products will be added to the platform in future.
Features:
NEW! Neural Hybrid Engine version 2.0
Used in Dual Rectofire model.
NEW! Power Link technology
Affects the power supply linkage between poweramp and preamp.
Freely movable module windows inside the plugin
Keep open only those modules that you need.
Preamp/poweramp can be switched off independently
More options, more flexibility.
Same oversampling cycle for pedals/preamp/poweramp
No latency build-up and no additional sound quality losses.
Stereo-mode
When used, right/left channels are modeled independently.
Delay and reverb can be used in parallel
No extra routing!
Plugin supports CPU multi-threading
More cores = better plugin performance.
Standalone version
No DAW? No problem, you can still use Ampbox.
Factory and user presets
Robust preset system and manual preset sharing options.
Home Page -
