Print2CAD 2024 AI converts all PDF vectors, PDF raster images (vectorization), native and non-native PDF text (OCR). Print2CAD 2024 AI recognizes circles, arcs, right corners, rectangles, frames, crosses, small symbols. Powered by OpenAI. Print2CAD 2024 AI converts or recognize layers, linetypes and line weights.
Perfect PDF to DWG/DXF conversion
Print2CAD 2024 AI converts all PDF elements into full editable CAD elements. All PDF lines, polylines, splines, texts, circles, arcs, layers will be converted into native DWG/DXF entities.
Print2CAD 2024 AI vectorizes all PDF raster pictures as DWG/DXF vectors or solids using "Center Line Tracing", "Outline Tracing" or "Solidization" as vectorization methods.
Print2CAD 2024 AI uses Artificial Intelligence (AI) Methods for H/V line recognition, right corner recognition, solid walls recognition, symbol recognition and OCR of text.
Print2CAD 2024 AI applies Optical Character Recognition (OCR) to all kind of text (line, hatch or raster) and with all inclination angles.
AI PDF Raster 2 Vector and OCR of Text
Print2CAD 2024 AI offers vectorization of PDF raster pictures as DWG vectors or solids using special vectorization and contourization methods.
Raster image preprozessor with filling of small holes and connection of broken pixel traces corrects automatic raster pictures before vectorization and OCR of Text.
Alternative vectorization as center line, outline or solid. Separation of parts of a raster picture (homogenization) and applying of appropriate raster to vector method on separated pictures.
Print2CAD 2024 AI v24.15 (x64) (129.51 MB)
NitroFlare Link(s)
