Free Download reaConverter Pro 7.796 Multilingual Portable Free Download | 433.2 Mb
An elegant and powerful utility that helps you batch edit images, then convert them to a multitude of other formats, such as PNG, JPG, TIF or BMP. ReaConverter is an application designed to help you easily convert image files, as well as perform other operations, such as resizing. The interface of the program is plain and simple. You can use the Explorer-based layout to locate and access pictures. Batch processing is supported.
Highly efficient software that makes it easy to convert millions of files and folders in a single operation. Convert between a great number of file formats, including archaic and rare ones.
Features:
Ultra-fast multi-threaded conversion
The entirely reworked user interface
New image editing options and graphic filters
New formats support including CAD and MS Office documents
New ways to save the conversion result
New Watch Folders feature to monitor folders and automatically apply processing
New command-line tool for simple integration to server-side and third-party solutions
System requirements:
Windows XP, Vista, 7, 8, 10, 11
Server 2003 - 2022
