- · Megnézett téma Ableton Live 11 Suite v11.3.25
- 15,542
File Size: 4.83 MB
Pre-Cut Optimizer is a calculation program for cutting optimization of standard profiles and other bar material.
The integrated, fully editable parts list serves as the basis for the calculation. It is possible to import parts lists from MassCalc professional (from version 6) and parts lists from text files or the Windows clipboard. Parts lists can also be exported as CSV or text documents.
As a result of the calculation, you will receive a detailed cutting list with all items to be cut, alternatively a bar list with a graphic representation of the previously selected bar, a leftover list and a corresponding requirements list (order list). You can print out these configurable lists or make them available to other software via the Windows clipboard for further processing.
