Steelray Project Viewer 6.18 | Size: 94.25 MB
Steelray invented the viewer for Microsoft Project in 2000 and has continuously added innovations and improvements since then. There is no need to import or upload anything - simply open the file as you would with Microsoft Project, and you'll see the same core views and data in the schedule.
Enterprise Ready
Steelray Project Viewer is used by customers in the industries with the largest project schedules (e.g. Aerospace/Defense, Construction).
Enhanced Printing
Preview all pages, one page or actual size before printing. Scale and see the effects on the output, control page size and orientation and header data. Easier than printing in Project!
Search Engine
Find what you need rapidly with the first search engine integrated into a project viewer. Search through task information, resource names and dates.
Platform Ready
Microsoft Project 98 through Project 2016, Excel, Primavera .XER and UN/CEFACT XML files.
One Click Navigation
Click on a task and see the detailed information. Select a resource name and you'll see the assignments for that resource. Click on a date and see what is starting, finishing and in-progress.
Easy to Use
An improvement on the original, not a clone of Microsoft Project. Simplify project data for all who need it.
