Togu Audio Line TAL-Drum 2.1.3 | Size: 19.65 MB
TAL-Drum is an easy-to-use sampler for drums, short samples, and loops inspired by the 80's drum samplers with a modern workflow.
Superfast workflow with sample, pad, and mapping drag and drop.
32 pads with 4 layers.
Up to 16 stereo outputs.
One LFO, spline envelope, amp AHDSR and two modulation AHDSR for every mapping.
Different time stretch modes (high quality Crisp or Smooth, Vintage AK4I Cycle mode)
Realtime LO-FI effects.
Slice editor.
Record audio and create samples directly in the plugin.
More than 20 Factory kits and more than 600 samples by Goldbaby, emptyvessel, Solidtrax and Saif Sameer (demo has one kit).
Most common audio formats supported (wav, aif, flac, ogg, mp3..).
Super lightweight. The installer only copies the plugin to the plug-in location.
