Free Download Yum Audio Slap By Mr. Bill v1.3.6 | 21.2 Mb
Slap is the first plugin in Yum Audio's signature series dedicated to making the sounds of established producers available to everyone.
A simple but powerful purpose
Slap combines a unique click-replacement tool with a multi-effect unit. Each of the included effects is carefully designed to create snares and kick drums that slap and add punch to your tracks.
Slap is a collaborative effort between Mr. Bill and Yum Audio dedicated to making Mr. Bill's special production techniques and sounds available to you.
Key Features
Add instant fat and slap to any drum sound.
Signature sounds and handcrafted presets by Mr Bill.
Unique Click module with the power to replace or layer any transient.
6 intuitive FX modules that could each be considered a plugin on its own:
Clap module that adds a synthesized noise clap to any sound.
Powerful transient shaping with the Shape module.
Fat module to add fat and punch easily via multiband compression and EQ.
Spray module to add lush reverbs and sustains to your drum sounds.
Clipper with a Punish and Timbre control.
Sub module to add earth-shattering sub to any source.
Routing of all FX modules via intuitive drag-and-drop actions.
Tone section to add glue everything together and control low and high-end frequencies with precision.
A global Tune control to alter every process inside the plugin and allow you to easily retune your whole drum.
A global FX Amount control to scale the processing amount of all FX modules at once.
Pinpoint waveform display with multiple visualization modes.
