Free Download Acustica Audio Sienna Bundle 2023 | 628.6 MB
Sienna is an Acqua plugin suite available in VST3, AAX, and AU formats. It's an ambitious project that represents a massive investment of time and energy, as well as years of painstaking design and development. The outcome of this effort is one of the most extensive, complex, rich plugins that Acustica has ever created: Sienna completely changes audio engineers' capacity to mix on the go.
It recreates the very same listening experience as if you were mixing in top-tier, acoustically designed studios or mastering in audiophile-grade rooms. It also gives you the option to play back your tracks through the "speakers" of various hi-fi systems, car stereos, boomboxes, and more - all through your headphones.
Sounds too good to be true, right? Sienna includes over 200 true-to-life emulations from the world's most famous headphone brands, which we carefully measured and profiled. In addition, it contains accurate models of 3 world-class studios (the Acustica Control Room, HOG Studio Control Room 1, Spitfire Mastering Atudio), 8 sets of high-end monitors, 2 consumer devices, and 3 new HOG Studio 1 room emulations based on the newly installed Dolby Atmos Sound System (stereo, surround sound, and surround sync).
Notes: Unlike other available Volumes, Sienna Volume A is not available as a separate download in Acquarius. The only way to obtain this Volume is through the installation of the Sienna plugin.
Additional Volumes or packs will require Sienna to be pre-installed on your computer.
A witch says,
Library is completely decrypted, decompressed, DRM related bloat removed, and built to the clean one.
This bundle includs Sienna, Sienna Guru, Sienna Sphere, and Sienna Volume B-G. Sienna Sphere does not support VST2.
According to the developer :
We are very sorry to announce that every single behevior of your DRM is defeated. Rebuilding the library is the hardest achievement for your protection, because we need to know every single encryption layer and Nebula2/4 Image structure which is not publicly documented at all. People can say it's fully reversed / cracked - minor DRM change can't stop us anymore. You need to change everthing from scratchA tartalom megtekintéséhez szükséges: Bejelentkezés vagy Regisztráció to view quote content!
home page
