AVG Cleaner - Storage Cleaner v23.17.0 build 800010279 | 39.76 MB |
With AVG Cleaner, your Android device will run faster and smoother, store more data, free up memory by cleaning junk, and stay charged for longer. AVG Cleaner is a smart device manager & optimization tool already installed by almost 50 million people.
AVG Cleaner top features
• Remove preinstalled apps - Remove pre-installed apps to save space and boost performance
• Get more space - Remove junk files, uninstall apps, and delete bad or unwanted photos and videos
• Improve performance - Use Cleaner to clear cache, remove junk, and identify apps that are slowing down your device (RAM Cleaner & memory booster)
• Longer battery life - Cleaner's battery saving feature helps improve your device's battery life
• Hibernate apps - Suspend background apps to prolong battery life and save mobile data
• System info - Everything you need to know about your phone on one screen
• File manager - Smart File Manager & Storage Cleaner can analyze pictures, files, and apps to help you maximize your Android device's performance
• Junk Cleaner - Clean out any useless junk from your device e.g. cache and app data
With AVG Cleaner, you will enjoy a longer battery life, avoid a lagging Android device, get rid of junk files, and automatically find bad quality or duplicate photos
AVG Cleaner - Memory (RAM) Booster and Junk Cleaner is a smart analysis application and clean up tool that gives you more storage space, better performance, and longer battery life
The booster, memory cleaner (RAM Cleaner), cache cleaner, battery saver, storage clean up, and app removal features are described below
Cleaner: Advanced app remover & app manager
• Remove preinstalled apps: Do you have pre-installed bloatware apps you don't need? We can prevent them from slowing down your device
• App analyzer: AVG Cleaner can identify apps that consume your battery, drain mobile data, or take up too much storage space, allowing you to clean them out more easily
• App remover: Easily remove apps that slow down your device
• RAM cleaner: Clean RAM and boost performance of your phone in a few taps
• Cache cleaner: Clear out app cache, temporary files and leftover data
• Easily analyze apps based on storage, ram, battery, data consumption or usage
Cleaner: Photo Analyzer
• Fast and easy photo gallery optimization
• Find bad quality or duplicate photos
• Easily clean your photo library
Cleaner: Battery Saver & Optimizer
• App hibernation: Hibernating apps help you prolong battery life and keep your device running faster for longer
• Battery Profiles & Optimization: choose between "Low Battery", "Home", "Work", and "Car" profiles, or set up your own to automatically adjust your battery usage how you want
Cleaner: 1-tap Analysis and Optimization
• Clean your device with a single tap of a button
• Perform device scan and analysis with just one tap
Media Overview
• Access Image Analysis results
• Optimize pictures to save space
• Sorted media by source folders
• All large video files in one view
App Overview
• Draining apps analysis
• Usage statistics
• App size growth analysis
• Notification analysis
• Quick boost feature
Professional version
AVG Cleaner - Storage Cleaner v23.17.0 build 800010279 (39.76 MB)
