File size: 65 MB
Creating a stunning video from the footage you took with your phone, ready to be posted on social media or blogs, using this application. BeeCut is a lightweight, yet feature-rich video editing tool designed to help you enhance your media before publishing or uploading. Packing hundreds of filters and templates, the tool can come in handy for a wide variety of situations.
Packs an editor to enhance your media files
The program comes with a modern and sleek interface that is also well-organized and unlikely to give you any trouble. As indicated in the tips, you can get started by importing a single file or a directory. On a side note, the app supports a wide range of aspect ration, including 16:9, 9:16 and 1:1, the latter being well known as working for Instagram. You will be happy to learn that the application comes with several advanced editing tools to help you make the most out of your video. Therefore, you can add various sizes and styles of creative masks, adjust the color, include pictures into the main image as well as customize footage on video, audio, PIP, overlay, filter tracks simultaneously, just to name a few.
Allows you to add dozens of overlays, audio and transitions
In addition to the masks and standard customization, the program enables you to add numerous amazing filters and overlays with drag and drop. Moreover, you can remove or replace the background sound seamlessly or just configure the speed and volume of the one already existing. You can make the entire video even more dramatic by applying multiple vivid filters or transitions for a more appealing and perhaps, natural feel. In the eventuality that you are working on promotional material and would like to add text, then take note that you have several templates to choose from. As you would expect, you can further change the font size, color and style as well as align the message in the most appropriate location for your project.
A user-friendly video and media editing tool
Coming in an intuitive interface and with a simple functionality, BeeCut can be a suitable multimedia editing tool for various occasions, including short video ads, educational content, wedding anniversary, training conference or any promotional material for that matter.
BeeCut, Incredibly Easy Video Editor
Anyone can create stunning videos in no time!
Basic Functions for Daily Editing
- Accurately cut a frame of video, delete unwanted parts and merge clips with just one click.
- Enhance your video with numerous fantastic overlays and filters, just drag and drop!
- Select your favorite style from crafted templates when you need to add text to a video.
- Edit audio by adjusting speed or volume. Replacing background sound has never been easier.
- Apply multiple vivid filters to your video to enhance the visual experience and add a natural feel.
- Add a mosaic effect to the video to disguise any aspect you chose.
Support Various Aspect Ratios
This video editing software supports editing videos with 16:9, 4:3, 1:1, 9:16 and 3:4 aspect ratios. The rendered video is compatible with the well known video platforms including
Advanced Video Editing Features
- Edit video by customizing parameters such as contrast, saturation and hue.
- Create picture-in-picture effect which allows you to play several videos on one screen.
- Edit footage on video, audio, PIP, overlay, filter tracks simultaneously and effectively.
- Make your video dramatic by adding various sizes and styles of creative masks.
Bring Your Stories to Life or Work
Using this movie editor, you can create a professional video that can be applied in different situations. It is your best choice for creating educational content, program introduction, short video ads and so on.
