| 185 |
But if you already have some experience in working with "Tinkercad", then you can now look forward to implementing more great projects. This way you can deepen your skills in designing 3D models. As you may already know, I am a professional engineer (M.Eng.) and in my books I try to teach you technical processes and how to use software in the easiest and most playful way possible.
In this book we will get to know four more projects for designing 3D objects in "Tinkercad". Some of them are very complex, while others are a bit easier to create. But don't worry, we will work through these projects together and step by step. This will help you to become even more familiar with the features of "Tinkercad" and also to learn some new approaches for developing your own 3D models. The more guided practice you have, the better you will be able to handle more complex projects of your own.
No matter how old you are, whether you are still in school, an adult, a student, or a retiree, this book will help you learn quickly and easily with the help of numerous illustrations. The software is suitable for all ages. You already know the basics of designing with "Tinkercad", so we'll start with the first design project right away. The first project will be a little easier, in order to get reacquainted with the software, but then the level of difficulty will increase from chapter to chapter.
This book is intended for those who already have a good working knowledge of designing 3D models using Autodesk's "Tinkercad" software. It is the sequel to the book "CAD Projects with Tinkercad 3D Models Part 1" (ISBN: 9783987421129).
The benefits of this book at a glance
Step-by-step explanations by an engineer (Master of Engineering) on how to use the "3D Designs" section in Tinkercad
Hands-on learning with four great projects and step-by-step illustrations
Course content: table lamp, bicycle, retro alarm clock, rim
Easy & straightforward for quickly improving your 3D modeling skills using Tinkercad
Simple and understandable explanations. Suitable for pupils, students, employees, tinkerers & inventors as well as retirees and all age groups
Learn everything important quickly
️ CAD Projects with Tinkercad 3D-Models Part 2 Create some more great 3D designs and become a Tinkercad pro.pdf (11.86 MB)
CAD Projects with Tinkercad 3D-Models Part 2 Create some more great 3D designs and become a Tinkercad pro (11.86 MB)
