Requirements: Android 6.0+ | File size: 6,35 MB
Device Info is a simple and powerful Android application that gives you complete information about your mobile device with advanced user interfaces and widgets. For example, device Info/ phone Info includes information about CPU, RAM, OS, Sensors, Storage, Battery, SIM, Bluetooth, Network, Installed Apps, System Apps, Display, Camera, Thermal, etc. Also, device Info/ phone Info can benchmark your device with hardware tests.
? What's Inside
- Dashboard: RAM, Internal Storage, External Storage, Battery, CPU, Sensors Available, Apps Installed & Optimizations
- Device: Device Name, Model, Manufacturer, Manufactured Date, Device Age, Device, Board, Hardware, Brand, IMEI, Hardware Serial, SIM Serial, SIM Subscriber, Network Operator, Network Type, WiFi Mac Address, Build Fingerprint & USB Host
- System: Version, Code Name, API Level, Released Version, One UI Version, Security Patch Level, Bootloader, Build Number, Baseband, Java VM, Kernel, Language, Root Management App, Google Play Services Version, Vulkan Support, Treble, Seamless Updates, OpenGL ES & System Uptime
- CPU: Soc - System on Chip, Processors, CPU Architecture, Supported ABIs, CPU Hardware, CPU Governor, Number of Cores, CPU Frequency, Running Cores, GPU Renderer, GPU Vendor & GPU Version
- Battery: Health, Level, Status, Power Source, Technology, Temperature, Voltage, Power(Watts), Current(mA) & Capacity
- Network: IP Address, Gateway, Subnet Mask, DNS, Lease Duration, Interface, Frequency, WiFi Standard, Security Type & Link Speed
- Connectivity: WiFi, Bluetooth, NFC, Ultra Wide Band and USB capabilities
- Display: Resolution, Density, Font Scale, Physical Size, Supported Refresh Rates, HDR, HDR Capabilities, Brightness Level & Mode, Screen Timeout, Orientation
- Memory: RAM, RAM Type, RAM Frequency, ROM, Internal Storage & External Storage
- Sensors: Sensor Name, Sensor Vendor, Live Sensor Values, Type, Power, Wake-Up Sensor, Dynamic Sensor & Maximum Range
- Apps: User Apps, Installed Apps, App Version, Minimum OS, Target OS, Installed Date, Updated Date, Permissions, Activities, Services, Providers, Receivers & Extract App Apks
- App Analyzer: Analyze all your applications with the help of advanced graphs. You can also group them by target SDK, min SDK, install location, platform, installer & signature.
- Device Tests
Benchmark your device with the following parts and check your device with Automatic tests. You can test Display, Multi-touch, Flashlight, Loudspeaker, Ear Speaker, Microphone, Ear Proximity, Light Sensor, Accelerometer, Vibration, Bluetooth, WI-Fi, Fingerprint, Volume Up Button & Volume Down Button
- Temperature: All the thermal zone values given by the system
- Camera: All the features supported by your camera
- Themes: Supports dark theme & custom colors
- Customizable Widgets: Fully customizable widgets with 3 sizes which display the most important information
- Export Reports: Export customizable reports, Export Text Reports, Export PDF Reports
? Donate / mod version
️ Device Info Phone CPU, System V3.3.5.24 (6.36 MB)
