DigitalVolcano Duplicate Cleaner Pro 5.20.0 Multilingual | Size: 66.2 MB
Duplicate Cleaner is a useful program to help you organize the contents of your home hard drive or corporate network. You'd be surprised just how many redundant or duplicate files you could find forgotten in an obscure documents folder. Duplicate Cleaner will deep scan for all types of filephotos, music, films, video, Word documents, PowerPoint presentations, text fileyou name it, if it appears twice on your computer then Duplicate Cleaner will find it. Once these files are found you are provided with helpful tools to enable you to select which copies to delete or move.These files can be deleted to the recycle bin or moved elsewhere.
FIND DUPLICATE FILES
An easy to use interface helps you tell Duplicate Cleaner where to look and what to look for. The unique Selection Assistant will help pick the files to remove. You can delete the files or move them somewhere else for later.
SORT OUT YOUR PICTURES
Finding similar photos or imageeven when edited, rotated or resized - is no problem with Duplicate Cleaner. You can even match by time taken and other tags.
TIDY UP YOUR MUSIC COLLECTION
Duplicate Cleaner can scan all popular music formats. Powerful algorithms allow the matching of tracks by similar or exact audio content. You can also match by tags such as Artist and Song Title.
FIND DUPLICATE VIDEOS
Duplicate Cleaner can now find similar videoall popular formats supported. Match by frames, soundtrack or metadata.
MORE POWER WHEN YOU NEED IT
Duplicate Cleaner has enough features to satisfy even the most demanding power user: find duplicate folders, unique files, search inside zip files, advanced filtering, automated selection, virtual folders and much more.
GETTING YOU STARTED
We have useful online video tutorials for Duplicate Cleaner. If you want to dive deeper there is a full searchable manual and an active discussion forum.
What's new
Supported Operating Systems: Microsoft Windows 11, 10, 8 or 7
