Free Download DxO PhotoLab Elite 6.9.0 Build 267 Portable (MULTi/2023)
DxO PhotoLab is a powerful RAW image converter and editor. Uses modern patented technologies with which you can adjust brightness, contrast, color balance, eliminate distortion and improve image clarity, correct colors and exposure at the edges and corners of a photo, adjust white balance taking into account color temperature, and much more.
Information about the program:
Year of manufacture: 2023
Platform: Windows® 11/10/ (64-bit only)
Interface language: English / Francais / Deutsch
Medicine: not required / built-in | pre-activated
File size: 742.95 MB
DXO Smart lighting
- Optimizes the dynamic range of your image and brings out details from overexposed areas.
DxO Clearview
- Intelligently enhances local contrast and effectively removes distant smoke.
DxO Prime
- Automatically de-densifies ISO RAW images and restores precise details and colors based on our exclusive algorithms.
Optical corrections
- Use your device with automated adjustments based on DxO's renowned scientific measurement and calibration expertise.
Your creativity
- Give your photos your own artistic touch by manually applying selective adjustments to specific areas of your image using DxO's exclusive local adjustment tools, which include: control points (U Point technology), graduated filters, manual and automatic brushes, auto-correction tools, and more .
Management
- Manually select the editing area by simply clicking on the part of the image you want to adjust.
Brushes
- Freely paint and manually adjust small or large areas of the image.
Gradient tool
- Simulates a graduated ND filter and allows you to apply artistic effects.
Deleting objects
- Allows you to remove dust spots or unwanted objects from your photos.
Processing a series of photographs
- Intelligent algorithms adapt settings to your hardware as well as graphic content
- Copy and paste settings from one image to another
- 30 built-in presets, fully customizable to give your photos the look you love
- Multiple exports in one click
- Export to several formats for the Internet, print or backup, export to social networks, photo editors
Adaptation to workflow
- Direct access to images
- Seamless integration with Lightroom via plugin
- Customizable workspace to adapt to your needs
- Dual screen compatibility
Whats New in version DxO PhotoLab 6:
DeepPRIME XD reduces noise and enhances detail like never before
DxO's pioneering DeepPRIME technology has evolved. The unique, AI-powered RAW denoising engine can give photographers more than two extra stops of ISO performance and remarkable detail.
The new DeepPRIME XD is more powerful than its predecessor. Thanks to a neural network that is now three times larger, its denoising and demosaicing processes retrieve previously unseen levels of detail, improve color, and smooth out bokeh.
Better colors, naturally
Enjoy more accurate and lifelike photos with PhotoLab 6's new wide gamut color space.
Far exceeding Adobe RGB, it uses spectral primary colors for natural, vibrant results, particularly in highly saturated images.
The upgrade means you can boost colors while avoiding clipping in saturated regions. Plus, the new color space also means the ClearView Plus tool can achieve even better results as it has more colors to work with.
As a result, DxO PhotoLab 6 is also a perfect fit with the latest generation of wide-gamut monitors.
Soft Proofing mode for perfect prints
Ever struggled to transfer the color and tone of on-screen images into print? Thanks to DxO PhotoLab 6's new Soft Proofing mode, preparing images for print has never been easier.
Guarantee sublime, accurate color at every stage of your RAW workflow, from management to editing, to hanging your prints on the wall.
Clone and repair with unrivaled flexibility
Complex retouching normally needs tricky layers and masks, but DxO PhotoLab 6's ReTouch tool introduces unrivaled flexibility, letting you make all the edits you need without switching to another package.
Take your cloning or healing source point then quickly flip, rotate or scale it to make perfectly natural edits.
Get organized the easy way with new color labels
Color labeling comes to DxO PhotoLab 6, giving you more options for organizing, filtering, and searching through your images.
Color code your files with simple shortcuts then search just as easily, all without the need for messy, complicated catalogs.
Get a new angle
DxO PhotoLab 6 acquires powerful new keystoning tools, letting you manipulate the perspective of any photo.
Fix converging vertical and horizontal lines and achieve symmetry and balance with ease.
Information about the Portable build
Does not require installation of libraries on the system.
Leaves no traces in the system or registry.
Minimum system configuration:
- CPU supporting SSE 4.1
- 8 GB of RAM
- 4 GB available disk space
- Microsoft® Windows® 10 version 20H2 or higher (64-bit, and still supported by Microsoft®)
Recommended system configuration:
- Intel® Core™ processor with 6+ cores or better, or AMD Ryzen™
- 16 GB of RAM
- 6 GB available disk space
- NVIDIA RTX™ 2060, AMD Radeon™ RX 6600 or better with latest drivers
Whats New in DxO PhotoLab 6
