Edge Card Launcher Side Panel v4.7.5 | 2.58 MB |
Edge Card Launcher is an overlay launcher with beautiful Material design and pleasing animations that is available from anywhere with one swipe. Using your device one-handed has never been easier!
Tons of functionality
- Adjust volume for music or active phone call
- Add app and contact shortcuts
- Control media players (play/pause, next/previous)
- Turn on/off built-in flashlight
- Open notifications shade
- Switch media output to speakers or bluetooth
- Open your default voice assistant
You can open the launcher from any screen - just swipe on the edge of the screen (pull & release). You can also double-tap the edge of the screen to open the launcher.
Edge Card Launcher needs one core permission to draw app overlays, and the following optional permissions for full functionality
- Modify settings: So you can adjust volume or auto rotate device screen;
- Camera permissions: So you can turn on and off flashlight (torch mode);
- Read contacts: So you can add your favorite contacts for easy access;
- Bluetooth: So you can control bluetooth device volume.
Edge Card Launcher Side Panel v4.7.5 (2.58 MB)
