- · Megnézett téma Firetrust MailWasher Pro 7.12.217 Multilingual
- 15,567
File Size: 7.35 MB
EDGE Diagrammer is our most versatile diagramming tool. Create a wide variety of technical, presentation, and design diagrams efficiently and with the highest quality results. EDGE Diagrammer is all you need for block diagrams, flowcharts, org charts, family trees, data flow diagrams and more. Free extension packs are available to provide support for many different diagramming methodologies. EDGE Diagrammer is the one-product solution for all your block and flow diagramming needs.
EDGE lets you define "styles" using hundreds of predefined drag-and-drop shapes and arrowheads. Save your styles in diagram templates to establish your own diagramming methods. EDGE Diagrammer comes with complete flowcharting templates, network diagramming templates, block diagrams, org charts, and more to get you started.
The program's workspace is especially designed for your ease, comfort, productivity, and enjoyment. Simple but old-style powerful toolbars and menus keep the most frequent tasks handy. Objects most common to a specific type of diagram are available with one click from the style bar on the left of the screen. And the screen itself shows you just what you need, exactly as it will print.
EDGE Diagrammer can create flowcharts and similar diagrams with minimal effort. As you draw your diagram, EDGE Diagrammer connects lines to figures and attaches labels to lines. It remembers these relationships and adjusts automatically when you move objects around. It can also adjust the size of a shape when you add text to it.
Includes pre-defined shapes and symbols organized in the Figure Symbol Gallery and several pre-defined diagram templates.
Support image raster (PNG, JPG, BMP, TIF, GIF) and vector format (WMF, EMF)
While direct PDF output is not supported, you can produce PDF files using a PDF printer driver.
