FolderSync Pro v3.5.3 build 2020100125 | 44.24 MB |
FolderSync enables simple sync to cloud based storage to and from local folders on the device SD cards. It support a wide range of different cloud providers and file protocols, and support for more platforms are added continuously. Root file access supported on rooted devices. Effortlessly sync your files. Backup your music, pictures and other important files from the phone to your cloud storage or the other way around. It has never been easier. Automation support using Tasker and similar programs enables fine grained control of your syncs.
FolderSync contains a full file manager, that enables you to manage your files locally and in the cloud. Copy, move and delete your files in your cloud/remote accounts. Support for creation/deletion of buckets in Amazon S3. Upload and download files from the phone. It's all supported.
Supported cloud providers
• Amazon S3 Simple Storage Service
• Box
• CloudMe
• Dropbox
• Google Drive
• HiDrive
• Livedrive Premium
• MyDrive.ch
• MyKolab
• NetDocuments
• OneDrive
• OneDrive for Business
• OwnCloud
• pCloud
• Storegate
• SugarSync
• WEB.DE
Supported protocols
• FTP
• FTPS (SSL/TLS implicit)
• FTPES (SSL/TLS explicit)
• SFTP (SSH File Transfer)
• Samba2/CIFS/Windows Share
• WebDAV (HTTP/HTTPS)
Paid version
FolderSync Pro v3.5.3 build 2020100125 (44.24 MB)
