logicabandoned
2022.11.12.
11,943
389
25
IK Multimedia ARC System 4.0.0 U2B macOS
File size: 56.2 MB
ARC 4 combines an ultra-accurate measurement microphone, analysis software and correction plug-in to improve the accuracy of your monitoring in any room. Work faster and more freely, confident you're hearing your music itself and that your music will sound great everywhere. With a faster, easier calibration process, breathtaking new more natural algorithm, and the ability to manage profiles on ARC Studio hardware, everything about ARC 4 is designed to let you focus on your music and create audio that translates to any system effortlessly.
Key Features
Measurement mic, room analysis software and correction plug-in
Improves frequency balance and stereo imaging in any room
Work faster and create better mixes without expensive room treatment
Virtual monitoring emulates the sound of common listening devices
Trust what you hear
A room can have a big impact on how you hear your music. Walls, furniture, and other objects reflect and absorb sound, creating complex artifacts that change the frequency balance and stereo imaging, and can cause your carefully balanced mix to fall apart in other spaces.
With ARC, you can detect and account for these issues without expensive room treatment. ARC precisely measures the sound of your room in moments, then generates a correction profile you can load into the ARC plug-in for your DAW or the new ARC Studio hardware, which operates independently from your computer, to ensure what you're hearing is how your music really sounds.
An all-new listening experience
ARC 4 uses a brand-new and more natural analysis and correction algorithm that delivers results you can't find in other digital room correction systems. By measuring your room across a 3D space around the listening position, IK's award-winning VRM™ (Volumetric Response Modeling) technology creates a 3D snapshot of your room, identifying problematic issues without over-processing the sound.
You have the choice of going through a 21-point ultra-accurate measurement process or a 7-point quicker one. Both will sound great. The longer measurement is more adequate for fixed installations and permanent setups, while the shorter measurement is ideal for on-the-go or ad-hoc setups, making it possible to measure the room in less than a minute.
The result is an incredibly natural-sounding correction like you've never heard. ARC 4 recreates the feeling of working in a properly-tuned room, without sounding "corrected."
Measure quickly and precisely
Just connect a measurement mic to your interface and launch the step-by-step room analysis software. You'll be guided through a series of measurements across your listening position, and with ARC's flexible placement options you can create measurements of multiple monitors and listening positions, so you can virtually adjust the sweet spot for clients or different setups.
DOWNLOAD
