- · Megnézett téma ReaConverter Pro 7.810 Multilingual
- 15,585
- 349
File size: 16.9 MB
This powerful data recovery tool speeds up the scanning and data recovery process due to iTop unique recovery algorithm. You don't need to wait for a long time to get data back. In Just Minutes, you can retrieve deleted files perfectly as you expected. Besides, Scan options are diverse for different needs. You can quickly find your lost data by Location and File Type.
Recover Any Data from Any Data Loss Situations
Data loss can be caused by many reasons, and damages may differ greatly. You may have encountered a hard drive crash, a hard drive formatting, a computer virus, and malware, or you just accidentally delete your project documents and photos or videos, iTop Data Recovery is powerful enough to handle emergent data loss issues instantly and securely.
iTop Data Recovery enables you to easily perform file recovery without limitations. More than 1000 file formats are supported. Meanwhile, this Windows data recovery software supports recovery on all types of storage media including hard drive, memory card, USB drive, and SSD, etc.
Up to 95% Success Rate
The Windows data recovery tool also provides a totally free visualization preview of the deleted, corrupted, inaccessible and formatted data, including Microsoft Office documents, photos, videos, and audios. Moreover, you get to know the status of each of your files, for example, Excellent, Good or Poor, making sure it is exactly what you are looking for and if the data is recoverable. The feature is remarkably helpful in ensuring a precise and smooth data recovery experience. With years of recovery experience, till now iTop Data Recovery maintains a high level of 95% recovery rate.
Hint
Data recovery success rate depends on several factors. For example, how much new data have you been written? If you didn't perform much operation after the file is deleted, it will be simple to undelete files. Earlier recovery ensures more chances of data recovery.
