Learn PostgreSQL, Second Edition | 745 | Luca Ferrari, Enrico Pirozzi | Packt |
PostgreSQL has become a widely adopted database engine thanks to its robust enterprise capabilities. This edition will not only help you get up and running with the latest changes in PostgreSQL but will also focus on its most important features; like transactions, security, replication, backup and restore, extensions and more.
This new edition will help you learn PostgreSQL from scratch with the latest version, providing a complete focused view on aspects like configuration, high performance, partitioning, backup, server-side programming and replication.
Purchase of the print or Kindle book includes a free eBook in PDF format.
Key Features
Learn the fundamentals of PostgreSQL 16, including SQL statements, replication, and security
Enhance your learning journey with the provided Docker images for practical hands-on exercises and tests at the end of each chapter
Get new and improved examples, use-cases, and scenarios specifically for concepts like partitioning, replication, back-up and restore, cluster configuration, monitoring and others
Book Description
The latest edition of this PostgreSQL book will help you to start using PostgreSQL from absolute scratch, helping you to quickly understand the internal workings of the database. With a structured approach and practical examples, go on a journey that covers the basics, from SQL statements and how to run server-side programs, to configuring, managing, securing, and optimizing database performance.
This new edition will not only help you get to grips with all the recent changes within the PostgreSQL ecosystem but will also dig deeper into concepts like partitioning and replication with a fresh set of examples. The book is also equipped with Docker images for each chapter which makes the learning experience faster and easier. Starting with the absolute basics of databases, the book sails through to advanced concepts like window functions, logging, auditing, extending the database, configuration, partitioning, and replication. It will also help you seamlessly migrate your existing database system to PostgreSQL and contains a dedicated chapter on disaster recovery. Each chapter ends with practice questions to test your learning at regular intervals.
By the end of this book, you will be able to install, configure, manage, and develop applications against a PostgreSQL database.
What you will learn
Gain a deeper understanding of PostgreSQL internals like transactions, MVCC, security and replication
Enhance data management with PostgreSQL's latest partitioning features
Choose the right replication strategy for your database
See concrete examples of how to migrate data from another database, perform backups and restores, monitor your PostgreSQL installation and more
Ensure security and compliance with schemas and user privileges
Create customized database functions and extensions
Get to grips with server-side programming, window functions, and triggers
Who this book is for
Learning PostgresSQL 16 book is for anyone interested in learning about the PostgreSQL database from scratch. Anyone looking to build robust data warehousing applications and scale the database for high-availability and performance using the latest features of PostgreSQL will also find this book useful. Although prior knowledge of PostgreSQL is not required, familiarity with databases is expected.
Table of Contents
Introduction to PostgreSQL
Getting to Know Your Cluster
Managing Users and Connections
Basic Statements
Advanced Statements
Window Functions
Server-Side Programming
Triggers and Rules
Partitioning
Users, Roles, and Database Security
Transactions, MVCC, WALs, and Checkpoints
Extending the Database- the Extension Ecosystem
Query Tuning, Indexes, and Performance Optimization
Logging and Auditing
Backup and Restore
Configuration and Monitoring
(N.B. Please use the Look Inside option to see further chapters)
9781837635641-LEARN_POSTGRESQL_SECOND_EDITION.pdf (12.61 MB)
9781837635641.epub (6.27 MB)
