SKIKDA
2023.05.28.
16,059
376
33
File size: 38 MB
Neevia Document Converter Pro is a software product that dynamically converts Microsoft Office 2003/2007/2010/2013/2016/2019/365, WordPerfect, HTML, AutoCAD DWG/DWF, EML, MSG, PostScript and many other document types to PDF, PDF/A, PostScript, JPEG, TIFF, PNG, PCX, BMP.
It operates in both a batch mode via directory or email scanning and in direct mode via a COM (ActiveX) component. Document Converter can be configured to recognize text - this is known as OCR - for the converting Image and PDF files and comes with support for printing the input files directly to a physical printer instead of converting them to PDF or Image.
With clustering and multi-threading support Neevia Document Converter Pro offers a reliable and stable conversion process.
Document Converter Pro is easy to install and is used by companies in the legal, pharmaceutical, insurance and in many other areas that generate voluminous documents. The goal of Neevia Document Converter Pro is to help your company create one PDF/Image standard that can be integrated into your workflow with ease and affordability.
A tartalom megtekintéséhez szükséges: Bejelentkezés vagy Regisztráció to view spoiler content!
