SKIKDA
2023.05.28.
16,844
411
33
File size: 1 GB
Trapcode Suite - The industry-standard package for motion graphics in After Effects. Red Giant Trapcode Suite is a set of 11 tools for 3D motion graphics and visual effects.
PARTICLE EFFECTS
Trapcode Suite brings the power of 3D particle systems right into After Effects. Use particle emitters to create fire, water, smoke, snow and other organic visual effects, or create technological marvels and user interfaces with immortal particle grids and 3D forms. Combine multiple particle systems into one unified 3D space for visually stunning results. With GPU acceleration, Trapcode plugins help you get beautiful results fast.
PHYSICS & FLUIDS
For the first time ever, run realistic fluid simulations using the new Dynamic Fluids™ physics engine, or emulate particles moving through the air and bouncing off surfaces.
3D OBJECTS & SURFACES
Create flowing surfaces, mountainous terrains, endless tunnels, and abstract shapes. Use paths and motion to generate beautifully complex geometric shapes, ribbons and extrusions. Whether you are creating motion graphics or visual effects, the possibilities are endless.
LIGHTS AND GLIMMERS
Bring light and life into your motion design. Simulate organic, 3D-camera aware volumetric lighting. Use masks and paths to add light streaks that can bring your logos and text to life and add starry glimmers to accent the highlights in your work.
SOUND AND MOTION
Use audio to generate keyframes that drive animation and effects. Scale, rotate and move to the beat, or use drum hits to create particle effects. Duplicate and offset layers and their motion with ease. Trapcode Suite gives you the power to automate complex animation easily.
TOOLS
New in Trapcode Suite 15.0
TRAPCODE PARTICULAR (NEW)
  • Updated Designer for building effects visually
  • Fluid dynamics
  • Text emitters
  • Mask emitters
  • 175 new presets (Over 300, in total)
TRAPCODE FORM (NEW)
  • Fluid Dynamics
  • Text forms
  • Mask forms
  • 150+ new Presets
TRAPCODE MIR (NEW)
  • Import OBJ models as Mir Surfaces
  • Included library of over 60 3D Models
  • 16 Surface presets for fast material setups
Windows 10 (x64)
Adobe Creative Cloud (2017 - 2020)
A tartalom megtekintéséhez szükséges: Bejelentkezés vagy Regisztráció to view spoiler content!
