Smart DNS Changer Pro v2.84r | 5.5 MB |
What does Internet Optimizer do? It is a special DNS changer application developed for Android devices. It also compares many DNS servers, finds and connects to the fastest DNS service. During this process, instantaneous delay (on the basis of ms) values are used. Tested DNS servers are ordered by latency. Its main purpose is to change DNS. It is intended for users to make the fastest DNS connection without hassle.
What is the order of Internet Optimize and DNS Change?
• Internet connection is checked.
• There is a connected network type (Wi-Fi, Mobile Network, 2G, 3G, 4G, 5G)
• The instantaneous delay of the normal connection is calculated (Ping time)
• DNS changer tests 17 different DNS services based on instant latency (Pings a global server.)
• DNS servers are sorted on the basis of their latency (Sorted by ping time)
• By configuring the fastest DNS server, a connection request is sent (Note: A VPN connection permission request may be shown to the user during this time.)
• DNS connection is completed.
• In the main interface, the connected DNS server, Ping time, network type information are updated.
What is Ping Monitor and how does it work?
This tool is a tool that is constantly updated in one corner of the screen, allowing the user to instantly see the ping time. It aims to let you know if there is lag or lag while playing the game. It can be useful for players to follow in online games. It is calculated by pinging a hub. The latency is based on the ping time. All network types are supported. This feature needs some permissions and internet connection to work properly.
Some special permissions needed for DNS Change
These permissions are required for DNS change operation. We need these permissions to calculate ping times and learn network type. Also, we need services so that the DNS changer can run in the background.
Permissions required for Ping Monitor
Ping monitor needs display permission on other displays. An internet connection is required for this service to work properly.
Paid version
Smart DNS Changer Pro v2.84r (5.5 MB)
