Free Download Stellar Toolkit for Data Recovery 11.0.0.4 (x64) Multilingual Portable Free Download | 167.7 Mb
Stellar Data Recovery Toolkit is an advanced software, trusted by technicians worldwide, for recovering the lost data from Windows, macOS and Linux drives. The tool can recover the data, lost due to deletion, drive formatting, corruption, lost partition, and system crash.
Recovers from hard drive, solid-state drive, USB drive, SD card, etc.
Recovers from lost or inaccessible RAID 0, RAID 5, and RAID 6 arrays
Recovers from virtual drives, namely VMDK, VDI, VHD, & VHDX file formats
Supports NTFS, FAT, exFAT, APFS, HFS, HFS+, Ext2, Ext3, & Ext4 file system
This is the core module to recover data from storage media based on APFS, NTFS, FAT, exFAT, HFS, HFS+, Ext2, Ext3, or Ext4 file system. Stellar Data Recovery tool can scan and restore the lost folders, documents, emails, photos, videos, and audio files, etc. of unlimited file formats.
Recovers data from crashed or unbootable system
Restores data from physical & virtualized storage
Recovers any type of data through file signature scan
Stellar Repair for Video
This module repairs the corrupted video files, captured with all major brands and types of camera devices. The tool can fix stuttering, flickering, blurry and all other types of corrupted videos on Windows PC and Mac. It can repair multiple 4k, 8k, 360? & VR videos, simultaneously.
Repairs 17+ videos file formats, including MP4, MOV, AVI, & MKV files
Repairs videos recorded with DSLR, drone, digital camera, etc.
Supports Nikon®, Canon®, Sony®, Go Pro®, Olympus®, Fuji®, etc.
Stellar Repair for Photo
This module specializes in repairing the corrupted or damaged image files, including JPEG and camera original (RAW) file formats. It can fix distorted, grainy, blurry, pixelated and greyed-out images, and it also resolves corruption in header and image file structure.
Repairs JPEG, ARW, CR2, CR3, CRW, DNG, ERF & more file formats
Repairs photos captured using DSLR, Android® phone, iPhone®, etc.
Supports Nikon®, Canon®, Sony®, Olympus®, & other leading brands
Stellar Drive Monitor
This is a tool for monitoring the temperature, health and performance of hard disk, and to also determine the status of SMART parameters such as Raw Read Error Rate, Seek Error Rate, Reallocated Sector Count, etc.
Performs real-time monitoring of vital disk parameters
Scans the disk to find out bad sectors on the disk
Performs disk cloning to facilitate data recovery
Key Features:
Recovers from All Types of Storage Drive
Stellar Data Recovery toolkit is designed for all types of storage drives, including hard drive and solid state drive, USB flash memory, hybrid storage, portable drive, memory card, optical storage, etc. It can also recover data from BitLocker® encrypted drive, after you enter the BitLocker password or Startup key.
Recovers from RAID 0, RAID 5, & RAID 6
The toolkit can reconstruct an inaccessible RAID array by using parameters such as disk order, start sector of RAID, stripe/block size, etc., and then scan the RAID volume to recover the data. Further, it can provide the probable values for RAID construction, when the parameters are unknown, thus allowing data recovery.
Constructs Virtual RAID for Data Recovery
In worst-case scenarios, the software allows to create a virtual drive if it is unable to rebuild a RAID or find the volume. It then performs RAW recovery, i.e. file signature-based search of lost data in the RAID volume image, and retrieves the data.
Recovers from Virtual Machine
The toolkit also recovers data from a virtual machine by mounting the VM image and scanning it like a physical storage. It can scan the visible partitions of the virtual machine or can also search and find the missing partitions, and scan those to retrieve the data. The toolkit can recover data from VMDK, VDI, VHD and VHDX images.
Supports Windows, macOS, and Linux Storage
The software can recover data from Windows storage media based on NTFS, FAT16, FAT32, exFAT file system. It also supports macOS storage, including APFS, HFS, HFS+ drives. And, the tool also restores the data from Linux storage having Ext4, Ext3, & Ext2 file systems.
Retrieves Data from Crashed System
The tool can create bootable media to access and recover data from a crashed or unbootable Windows PC or Mac. The bootable recovery media allows seamless access to the unbootable system, just like a working system, scans the hard drive or start-up disk and recovers the data.
Recovers Data from Corrupt Partition
A corrupted partition becomes inaccessible and needs "reformatting" to allow access. However, formatting the partition removes the data stored on the partition. So, you should first use this data recovery toolkit to access & scan the corrupt partition, and recover the files and only then proceed with reformatting. The software can recover data from APFS, NTFS, FAT, exFAT, HFS, HFS+, Ext2, Ext3, or Ext4 formatted partitions.
Recovers Lost or Missing Partition
The software can discover the lost or deleted partitions on a storage drive by using an option called 'Can't Find Drive' which involves scanning of the storage drive, particularly to search the lost and deleted partitions. This feature can also run Deep Scan, a file signature-based media scanning technology, to recover the partitions.
OS: Windows 11, 10 , 8.1 , 8 , 7 (64-bit only)
Memory: 4 GB minimum (8 GB recommended)
Home Page -
