Voxengo r8brain Pro 2.12.0 | 3.76 MB |
r8brain PRO is a professional sample rate converter tool software designed to deliver an unprecedented sample rate conversion (SRC) quality. Unlike other existing SRC algorithms available on the market, r8brain PRO implements sample rate conversion processing in its full potential: interpolation and decimation steps without exploiting any kind of simplifications; the signal is resampled in a multi-step manner using a series of least common multiple sample rates which makes conversion perfect - both in signal-to-noise and timing precision aspects. Such whole number-factored SRC can be considered a golden standard in sample rate conversion as it is not subject to jitter and timing errors.
Like many existing SRC algorithms, r8brain PRO offers you a linear-phase conversion mode. But more importantly, you also have an option of using the minimum-phase conversion mode, which finally brings SRC with true analog qualities to affordable digital audio workstations: in this mode, r8brain PRO works like an ideal digital-to-analog converter followed by an analog-to-digital converter to resample the audio. This eliminates pre-ringing associated with linear-phase designs, while introducing a minimal amount of phase coloration.
r8brain PRO can read mono, stereo and multi-channel files in WAV, RF64, Wave64 and AIFF file formats, creating 16-, 24- and 32-bit mono, stereo and multi-channel WAV files in fixed- and floating-point formats. EBU BWF (broadcasting) extensions, extensible wave format, markers, sample loops and textual data residing inside the file are also supported. For the sake of convenience, r8brain PRO allows you to perform multi-threaded batch conversions that utilize the full potential of your computer.
r8brain PRO's bit-depth conversion uses an industry-standard "flat" TPDF dithering. We have decided not to implement noise-shaping dithering because audio production software available on the market usually offers the user a noise-shaping dithering of some kind already (you can also use our Elephant plug-in for this feature). We also based our decision on the fact that the sample rate conversion process often adjusts peak structure of the original program material, thus, in many cases, making a subsequent peak-limiting a necessity. To prevent output audio from clipping we have implemented a level normalization feature.
Mono, stereo and multi-channel support
Linear-phase and minimum-phase modes
Selectable output signal bandwidth
Automatic peak normalization
Full WAV file support
RF64 file support
Broadcast wave extension support
Markers and loops support
Wave64, AIFF support (on input only)
Multi-threaded batch conversion
64-bit floating point processing
Standard sample rates support
Updates: official site does not provide any info about changes in this version.
Voxengo r8brain Pro 2.12.0 (3.76 MB)
